Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
In order to perform several of the repair guides for the Volvo 740, the rear wheels of the car must be raised off the ground. This guide will show you how to do this using a hydraulic car jack and jack stands.
Инструменты
Запчасти
Детали не указаны.
  1. Turn car off and remove keys from ignition.
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. Use hydraulic jack on frame of car to raise car. Place jack head underneath frame couple (pictured).
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame couple (pictured).
    • Only necessary to jack the car until the wheels are just off the ground.
  3. Place jack stand on frame of car and remove jack. Do not work under car supported only by hydraulic jack, serious injury or death may result.
    • Place jack stand on frame of car and remove jack.
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
Заключение
Isaac Nitschke
Участник с: 11.10.2010
67 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 3-28, Regan Fall 2010 Участник Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 15
За всё время: 1,915
