Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
When a car is driven, tires tend to wear unevenly. To extend the life of tires, it is important to rotate the tires every 30,000 miles. This guide will show you how to remove and rotate tires.
Выберете то, что вам нужно
Turn car off and remove keys from ignition.
Place car in park (automatic) or neutral (manual).
Engage parking brake.
Use hydraulic jack on frame of car to raise car.
Place jack head underneath frame of car.
Place jack head underneath frame couple (pictured).
Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
Pull hubcaps away from tires.
Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
Place tires on axels.
Hand tighten the lug nuts with narrow end of nut towards car.
Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
