1986-1993 Volvo 240 Brake Master Cylinder Replacement
Выберете то, что вам нужно
  1. 1986-1993 Volvo 240 Brake Master Cylinder Replacement, Brake Master Cylinder: шаг 1, изображение 1 из 1
    • The brake master cylinder is located directly underneath the brake fluid reservoir near the driver side of the engine bay.
  2. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 2, изображение 1 из 3 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 2, изображение 2 из 3 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 2, изображение 3 из 3
    • Twist the brake fluid reservoir cap counterclockwise and remove it.
    • Remove as much brake fluid from the reservoir as possible by sticking a clean rag inside the reservoir.
    • When you remove the rag, be sure not to place it on any painted or plastic surfaces. Brake fluid will strip paint and deteriorate plastic.
  3. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 3, изображение 1 из 2 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 3, изображение 2 из 2
    • If your brake fluid reservoir has a fluid level sensor, disconnect it by pressing down on the plastic tab and pulling the connector straight out of its socket.
  4. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 4, изображение 1 из 1
    • Use a 10 mm open end wrench to disconnect the two brake lines from the master cylinder.
    • There were still be fluid in the master cylinder that will drip out of the connections; this is normal. Use a clean rag to clean up any dripping fluid.
  5. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 5, изображение 1 из 2 1986-1993 Volvo 240 Brake Master Cylinder Replacement: шаг 5, изображение 2 из 2
    • Use an open end or socket wrench to remove the 17 mm nuts on either side of the master cylinder that attach it to the brake booster.
    • Remove the brake master cylinder, taking care not to damage or bend the brake lines.
Заключение
Don't forget to flush & bleed with new brake fluid! (separate how-to required)
5 участников успешно повторили данное руководство.
David Hodson
Участник с: 04/13/10
150 455 Репутация
Автор 127 руководств
3 Комментариев
Thanks this was great. Additional instructions are required about how to disconnect the reservoir from the master cylinder. I've broken so many plastic bits on my Volvo that I was scared to really put much force into getting the reservoir off. I kept thinking "There must be a trick..." but no there's no trick you just have to pull really hard while doing your best to not damage the reservoir. Could have saved me some time as I stared at it wondering what the "trick" could be.
There's also a plug on one side of the old master cylinder that you will need to take out and put on your new one.
Thanks again for posting these instrux.
Brant Louck - Ответить
Thanks very much David Hopson & very helpful.
M. T Lam - Ответить
David! Can you help!? Just got a 1991 Volvo 240 and the brakes went, just as you described. You mention that it is common with the 240? Can you elaborate?
Tracy Murphy - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 9,007
