1986-1993 Volvo 240 Distributor Rotor Replacement
Выберете то, что вам нужно
  1. 1986-1993 Volvo 240 Distributor Rotor Replacement, Distributor Cap: шаг 1, изображение 1 из 2 1986-1993 Volvo 240 Distributor Rotor Replacement, Distributor Cap: шаг 1, изображение 2 из 2
    • The distributor cap is located next to the engine and has all of the spark plug wires connecting to it.
    • Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
  2. 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 2, изображение 1 из 3 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 2, изображение 2 из 3 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 2, изображение 3 из 3
    • Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all.
    • Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap.
    • Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
  3. 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 3, изображение 1 из 3 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 3, изображение 2 из 3 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 3, изображение 3 из 3
    • Install the spark plug wire onto the new distributor cap and make sure it is seated properly.
    • Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap.
    • Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
  4. 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 4, изображение 1 из 2 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 4, изображение 2 из 2
    • Use a flathead screwdriver to release the clip securing the distributor cap.
    • Only one side of the distributor cap has a spot for the clip to rest. The new cap must be installed in the same orientation.
    • Remove the old distributor cap.
    • When installing the new distributor cap, don't forget to reconnect the center ignition coil wire.
  5. 1986-1993 Volvo 240 Distributor Rotor Replacement, Distributor Rotor: шаг 5, изображение 1 из 2 1986-1993 Volvo 240 Distributor Rotor Replacement, Distributor Rotor: шаг 5, изображение 2 из 2
    • The distributor rotor sits directly underneath the distributor cap and is not held in place by any screws or fasteners.
    • Lift the distributor rotor straight up and out of the distributor to remove it.
  6. 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 6, изображение 1 из 2 1986-1993 Volvo 240 Distributor Rotor Replacement: шаг 6, изображение 2 из 2
    • The distributor rotor is keyed, which means that the new rotor will only go on in one orientation.
Заключение
Place the new distributor rotor and cap back in the same orientation that the old ones were removed.
4 участников успешно повторили данное руководство.
David Hodson
Участник с: 04/13/10
150 580 Репутация
Автор 127 руководств
Один комментарий
I need to know how to install the whole distributor in the Volvo 240 DL. Do I still need to get #1 on TDC COMPRESSION and line the distributor/rotor facing #1 spark plug? Please help
Dave Miller - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 13
За последние 30 дней: 55
За всё время: 10,732
