1986-1993 Volvo 240 Front Brake Caliper Replacement
Выберете то, что вам нужно
  1. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: шаг 1, изображение 1 из 3 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: шаг 1, изображение 2 из 3 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: шаг 1, изображение 3 из 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: шаг 2, изображение 1 из 2 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: шаг 2, изображение 2 из 2
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Caliper Replacement: шаг 3, изображение 1 из 2 1986-1993 Volvo 240 Front Brake Caliper Replacement: шаг 3, изображение 2 из 2
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: шаг 4, изображение 1 из 2 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: шаг 4, изображение 2 из 2
    • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
    • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
    • Detach the brake hose and remove the brake caliper.
    • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
Заключение
Еще один человек закончил это руководство.
David Hodson
Участник с: 04/13/10
150 500 Репутация
Автор 127 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 6,256
