1986-1993 Volvo 240 Front Brake Rotors Replacement
Выберете то, что вам нужно
  1. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: шаг 1, изображение 1 из 3 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: шаг 1, изображение 2 из 3 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: шаг 1, изображение 3 из 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Calipers: шаг 2, изображение 1 из 2 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Calipers: шаг 2, изображение 2 из 2
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Rotors Replacement: шаг 3, изображение 1 из 2 1986-1993 Volvo 240 Front Brake Rotors Replacement: шаг 3, изображение 2 из 2
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Rotors: шаг 4, изображение 1 из 1
    • Pull the brake rotor straight off the wheel lugs to remove it.
  5. 1986-1993 Volvo 240 Front Brake Rotors Replacement: шаг 5, изображение 1 из 1
    • Place the new brake rotor over the wheel lugs.
    • Most new brake rotors can be installed without any additional work, but if your rotors are out of round they will need to be turned.
Заключение
To reassemble your device, follow these instructions in reverse order starting at Step 3.
3 участников успешно повторили данное руководство.
Brett Hartt
Участник с: 04/12/10
127 941 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 298 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 28
За всё время: 6,522
