Введение
Replacing the spark plugs in your SOHC inline-4 engine may be one of the quickest and easiest ways to provide a nice tune up for your Volvo 240. There is no real need to replace spark plug wires unless one breaks or fails, so see your manufacturer's service manual for recommended replacement intervals. Misfiring or a rough idle may be signs of one or more bad spark plug wires.
There are many aftermarket companies who manufacture spark plug wires that promise to increase performance and fuel economy. However, the most reliable and longest-lasting wires are usually OEM wires from the car's manufacturer. Factory spark plug wires can go hundreds of thousands of miles before requiring replacement.
Выберете то, что вам нужно
Disconnect the spark plug wire from the distributor cap by pulling it straight up.
Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
Install your new spark plug wires in the same manner that you removed the old ones.
2 участников успешно повторили данное руководство.
