Выберете то, что вам нужно
Find the hood lever, this is normally under the dash, to the left of the steering wheel.
Go to the front of the car and push the lever up to unlatch the hood, you may need to feel around for a minute to find this.
Once you have found the battery. It is time to unscrew the bolts holding in the wires.
If you see battery acid on the terminal bolts remove this be using baking soda mixed with water and a tooth brush.
Now with your 15mm wrench remove the positive terminal bolt, the same way you removed the negative terminal bolt.
With your 13mm socket, remove the bolt that holds the block, that holds the battery in. This bolt will not come out completely. Once you feel slack in the bolt you may remove the whole block.
Also find the right battery for this type of car.
6 участников успешно повторили данное руководство.
