Введение
An oil change should be performed every 5k miles and can easily be.
Follow this video tutorial by YouTuber NutzAboutbolts to do the job yourself.
Выберете то, что вам нужно
Видео обзор
Locate the oil filter under the exhaust manifold in the front of the vehicle
Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
Be careful not to burn yourself on the hot manifold.
Unscrew the oil filter and let it drain into the oil drain pan
Make sure the pan is aligned to catch oil from both the filter and drain plug.
Clean the mating surface where the new filter will be installed
Ensure there are no old seals or debris that could affect the new filter's seal
Еще один человек закончил это руководство.
