1991 Mustang HVAC Blower Motor Replacement
  1. 1991 Mustang HVAC Blower Motor Replacement, Unplug the Fan Motor: шаг 1, изображение 1 из 1
    • 1. Reach back behind the fan motor and disconnect the two pin power plug.
  2. 1991 Mustang HVAC Blower Motor Replacement, Mounting Details: шаг 2, изображение 1 из 1
    • 2. Squeeze the glove compartment sides inward to disengage the retaining tabs. Let the compartment door hang in front of the dash.
    • 3. Remove the upper air inlet duct housing to bracket screw. A 7/16” ratcheting wrench works well since clearances are tight. A socket will not fit.
  3. 1991 Mustang HVAC Blower Motor Replacement, Disconnect Vacuum Motor: шаг 3, изображение 1 из 1
    • 4. Disconnect the white recirc vacuum motor vacuum line from the top of the vacuum motor.
  4. 1991 Mustang HVAC Blower Motor Replacement, Duct Fastener Removal: шаг 4, изображение 1 из 1
    • 5. Close the glove compartment door and remove the lower two 5/16” screws from under the air inlet duct housing.
  5. 1991 Mustang HVAC Blower Motor Replacement, Remove the Fan Assembly: шаг 5, изображение 1 из 1
    • 6. The housing is now free to be removed from the dash. Gently lift the housing and tilt it clockwise to gain enough clearance to pull it free from the dash. I did not remove the lower right trim panel since it did not cause any interference.
    • 7. Disconnect the rubber cooling tube (recirc line) from the blower housing and the blower motor case.
  6. 1991 Mustang HVAC Blower Motor Replacement, Replace the Fan Motor: шаг 6, изображение 1 из 1
    • 8. Remove the four 5/16” screws that hold the blower motor assembly in the housing and gently pull the motor assembly free from the housing. Note that there is a foam gasket between the motor flange and the duct housing. Also note the orientation of the flat edge of the flange. It faces the outlet of the housing.
    • 9. Remove the metal pushnut from the blower motor and wheel assembly. I used a pair of needle nose pliers. The pushnut will likely be destroyed during removal. The replacement motor should come with a new pushnut.
    • 10. Separate the wheel assembly from the blower motor shaft by gently prying between the two with a suitable tool. Carefully pry around the two until you can slide the wheel off the shaft. Note that the shaft has a flat side that keys to the wheel.
    • 11. You may want to clean the ducting and wheel at this time. I used Clorox wipes for the inside of the ducting and a mixture of bleach and dish soap for the plastic blower wheel.
    • 12. Install the blower wheel onto the blower motor shaft by matching up the flats and pressing it into place by hand. Once the wheel is fully inserted, secure the wheel with a new metal pushnut.
    • 13. Apply some Permatex black gasket maker (or equivalent) around the motor cutout and gently slip the replacement motor and wheel assembly into place.
    • 14. Install the four 5/16” motor flange screws into the housing and tighten them. Do not over-torque.
  7. 1991 Mustang HVAC Blower Motor Replacement, Custom Recirc Hose: шаг 7, изображение 1 из 1
    • 18. My replacement fan motor did not have the motor cooling hole oriented in right location, so I modified it with Dorman PN: 47062 (universal 90 degree 5/8” heater hose elbow). The Dorman plastic elbow ends have to be cut back with a hacksaw about 3/4” from each end. The rubber hose can be cut with a pair of sharp scissors.
    • 19. Flip the motor end of the hose 180 degrees (backwards) so the 90 degree elbow will allow it to mate up with the housing end of the hose. Use a pair of hose clamps to secure the rubber hose to the 90 degree elbow. Do not overtighten the hose clamps as the hose rubber is quite thin. Measure twice, cut once.
    • 20. Take the completed air inlet duct housing with the motor installed back to the car.
    • 20. Since the replacement does not come with a power plug installed, you will have to cut the factory plug off (sorry). Connect the blower motor power leads to the factory wires with suitable electrical connectors. I used 12GA solder splices. Keep in mind that the motor will pull 16 to 22 amperes continuously when running in HIGH speed.
Заключение
2 участников успешно повторили данное руководство.
Jeremy
Участник с: 11/11/12
213 Репутация
1 руководство автора
Один комментарий
Great article ,very helpful,i have a 91 and will be doing the complete HVAC box when the time comes,where the motor installs and you mention permatex isn’t it actually butyl? my car being as old as it is around that area its spewing something that really looks like butyl which Ford used under the heater core also to keep it in place,im sure permatex will work just fine.
On ebay (my salvation sometimes) you can still find OEM motors very inexpensive,some parts for these cars are impossible to find and others are still around by the dozen,not sure why, maybe they didn’t get replaced much,i consider myself a pretty good researcher and finding a oem heater core has been impossible so ill have to do the Chinaman special.
dntlss - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 19
За всё время: 4,267
