Введение
In this guide, you will need very few tools to replace your header panel. This is a fast, and safe way to replace your header panel. Out of caution, before completing make sure your vehicle is shut off, and your emergency break is applied.
Выберете то, что вам нужно
Remove the two screws on top of the headlight bezel, and the two 11mm bolts on the back of the bezel.
Then, remove the bolts from the housing. Repeat this step for the other headlight.
Remove the headlight bulbs from the headlight housing by turning them counterclockwise on the retaining clip.
Reinstall the headlight bezels after reinserting the marker lights with the two screws, and two 11mm bolts.
Еще один человек закончил это руководство.
Один комментарий
My header panel was broke. Into like 5 pieces. I had everything pulled off my front end before realizing that I had not mapped out my process. This really helped me put it all back together.
I would love a parts source guide for all of the clips, fasteners and screws for all of this as some of mine were beyond reuse.
