Введение
Although this is a relatively simple fix, without a clear understanding of how to remove the bulb you may end up doing much more work than is required or even potentially permanently damage your car's wiring. Also this is an absolute necessity to fix as the front headlights are crucial for the safe operation of your vehicle.
Located right behind the headlight is a red Deutsch connector. Push down on that connector to unplug wiring and rotate unconnected portion counterclockwise, facing from the driver's view, to remove bulb.
6 участников успешно повторили данное руководство.
