Введение
This guide is for the purpose of demonstrating how to remove and replace the headlights in a 1994-2004 Ford Mustang. There are no safety hazards for this fast fix, and the difficulty level is not high. To complete this fast fix, no prior mechanical experience is needed beyond knowing how to tighten and loosen a screw. Since the car is old, you may need to lubricate certain parts to assist in the removal of them, and some connecting pieces may be worn or broken. The bulb can easily be found at an auto-parts store.
Prior to beginning your guide, make sure that your car is off and the emergency break is on.
Выберете то, что вам нужно
To open the hood, pull the release lever by your foot break inside the car.
Pull on the edges until the cover pops off revealing the nut shown in the next step.
Remove the bulb from the connector by pulling the two apart.
Connect the new bulb to the connector.
In the same area where you removed the screw, remove the clip by hand or use needle nose pliers.
Slide the 12mm wrench over the retainer and push until you are able to remove the headlight.
To push the retainers in so that I was able to remove the headlight, I pressed the handle of the wrench against the metal part of the retainers and pushed.
Similar to removing the turn signal, twist the headlight connector and remove the headlight from the bulb.
Еще один человек закончил это руководство.
