Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to remove the interior door panels to access multiple components. The method is almost exactly the same for the passenger's side, except there is no connector for the side-view mirror controls.
Выберете то, что вам нужно
Remove the plastic Phillips screw towards the front of the door panel.
Use a flathead screwdriver to remove the plastic clip that holds the screw.
Unscrew the Phillips screw in the bottom of the door panel cup.
Lift the cup out of the the door panel.
Insert a very thin flathead screwdriver blade into the small gap towards the rear of the car on the plastic screw cover near the door handle.
Unscrew the Phillips screw underneath the screw cover.
Remove the plastic cover at the base of the C-pillar by pulling it directly away from the window.
Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side.
Pull the bottom of the door panel away from the door, and lift the entire panel off the door.
Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
Use the same method described above to remove the connector for the tweeter.
Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
Disconnect the power window connector.
You may now remove the entire door panel.
5 участников успешно повторили данное руководство.
