1994-1997 Honda Accord Thermostat Replacement
Выберете то, что вам нужно
Видеоинструкции
Заключение
2 участников успешно повторили данное руководство.
eCuration
Участник с: 05/19/17
376 693 Репутация
Автор 234 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
4 Комментариев
If the thermostat is stuck shot would it make my 94 Honda Accord LX leak antifreeze from the driver side of the motor behind the tire
Robert Conklin - Ответить
That's crazy. That's what this 97 Honda accord does which belongs to a friend. I was thinking of buying it and he said it needs a thermostat. My brother said its leaking underneath . I thought maybe the water pump. Must be from the reserve tank overflow or where was your fluid coming from. I don't mind fixing a few things if I buy it. It needs motor mount already. So yours leaked too and it was thermostat? That's cheaper than a water pump. This car will get hot if it sits and idles for a little while. Driving it goes up n down. Well thanks…
Mike Johnson -
If my thermostat is stuck shut on my 94 Honda Accord LX would it make antifreeze leak on the right side of the motor driver side behind next to the tire is there some kind of relief valve over in that area when it goes to overheat if the thermostat is stuck is my question
When the thermostat is stuck shut, if the engine overheats, it will boil the coolant.  The added pressure in the engine will force coolant into the reserve container (driver’s side, forward of battery).  Eventually, some will overflow from the container.
Robert H - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 35
За всё время: 7,745
