1996-1998 Acura TL Front Door Panel Replacement
Выберете то, что вам нужно
  1. 1996-1998 Acura TL Front Door Panel Replacement, Front Door Panel: шаг 1, изображение 1 из 1
    • Roll the window down all the way and open the door as far as it can go.
    • Locate the screw cap in the bottom of the armrest cavity.
    • Remove the cap by finger or pry it off with a flathead screwdriver if necessary to reveal the screws beneath.
  2. 1996-1998 Acura TL Front Door Panel Replacement: шаг 2, изображение 1 из 1
    • Locate the screw cap inside of the door opening cavity.
    • Remove the cap by finger or pry it off if necessary to reveal the screws beneath.
  3. 1996-1998 Acura TL Front Door Panel Replacement: шаг 3, изображение 1 из 1
    • Unscrew both of the screws that are now uncovered.
    • One of the screws is in the armrest cavity, the other is in the back of the door handle's cavity.
  4. 1996-1998 Acura TL Front Door Panel Replacement: шаг 4, изображение 1 из 1
    • Wtth the screw gone, slide the entire wooden armrest unit to the right (away from the car).
    • Once the armrest can not go any further lift straight up out of its spot.
    • Before lifting too far reach under and remove the wiring from the wire harness by pinching down on the white tab and pulling straight back.
    • The window control is now removed and you can set the wooden door panel unit aside.
  5. 1996-1998 Acura TL Front Door Panel Replacement: шаг 5, изображение 1 из 1
    • Similarly wiggle the door handle frame to its right to remove.
    • You must move the handle out of the way as if opening the door to get the frame around it and out of the door.
    • Just like last time reach behind, pinch the tab and pull straight back to remove the circuitry for the door lock.
    • Once the entire frame is removed from the door and the circuitry, place it to the side with the armrest part.
  6. 1996-1998 Acura TL Front Door Panel Replacement: шаг 6, изображение 1 из 1
    • Pry the inside door frame off of the actual metal exterior door.
    • Use a flathead screw driver for leverage to pop all of the plugs off. Do not be afraid to use force as they are just snaps that will not break and will go back into place perfectly.
    • The locations of the plugs have been circled for your convenience. Although applying leverage at all points around the sides and bottom will pop them off just as easily and safely.
  7. 1996-1998 Acura TL Front Door Panel Replacement: шаг 7, изображение 1 из 1
    • Lift the door panel straight up and off. The metal strip on the top of the door panel will come with the panel as you remove it from the door.
    • It should slide off quite easily if all the plugs are unsnapped. Do not pull past the tension of the circuitry, as the wires are still plugged into the harness.
  8. 1996-1998 Acura TL Front Door Panel Replacement: шаг 8, изображение 1 из 1
    • Unplug the harness to the interior door light in the bottom right corner (farthest from the car)
    • Simply push down on the grey tab and pull straight out.
  9. 1996-1998 Acura TL Front Door Panel Replacement: шаг 9, изображение 1 из 1
    • Remove the interior door panel completely, exposing the inside of the door and the front speaker.
Заключение
3 участников успешно повторили данное руководство.
Brayden
Участник с: 10/05/12
16 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 18-42, Regan Fall 2012 Участник Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 39
За всё время: 3,183
