Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
    • Pull the hood latch to release the front hood.
    • Go around to the front of the car and trigger the lever to raise the hood.
    • Lift the hood prop and insert the end into the hood.
    • Locate the oil drain plug underneath the vehicle.
    • Put down some newspaper or cardboard to catch any spills or splashes
    • Slide the oil pan under the drain plug.
    • Take your 17mm socket and loosen the drain plug.
    • Once loose enough, remove the plug by hand.
    • The oil may be hot, so wear latex gloves when removing the plug.
    • Let the oil drain out until its just a drip.
    • Clean off the plug with a paper towel or rag.
    • Re-screw drain plug back into the oil pan.
    • Make sure it's not to tight or loose - check the owners manual for torque specifications.
    • Locate the Oil Filter on the underside of the car.
    • Remove the oil filter and let the oil drain out.
    • Re-add the new, fresh oil filter.
    • Add 4.8 Quarts of new oil.
Заключение
Еще один человек закончил это руководство.
Tim Asp
Участник с: 24.01.2011
1 297 Репутация
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 38
За последние 30 дней: 162
За всё время: 28,494
