Введение
With enough time, any lightbulb will burn out, and headlights are no different.
This guide demonstrates how to change a headlight in a 1997-2006 Jeep Wrangler. As opposed to many vehicles, the entire headlight assembly for this model must be replaced, not just the bulb. This guide will aid in disassembly and reassembly of the external and internal headlight bracket.
This is a straight forward process, requiring basic tools and less than an hour of your time.
Ensure that your vehicle is turned off and the emergency brake is engaged before beginning the repair.
Выберете то, что вам нужно
Remove the three 15.9 mm screws around the external ring casing with a Phillips #0 screwdriver.
Remove the four screws securing the internal ring casing with a T15 Torx screwdriver.
Disconnect the headlight assembly from the vehicle by pulling the connector directly out of the back port.
Reinstall the four screws securing the internal ring casing with a T15 Torx screwdriver.
Enjoy your bright new headlight(s)!
Еще один человек закончил это руководство.
