Введение
Shocks are dampening units that help your vehicle stop oscillating up and down. Without them, your vehicle would bounce excessively, handle poorly and even your braking distance could be adversely affected. Potential signs of worn or damaged shocks are the suspension feeling excessively stiff or soft, creaking noises coming from the shock area, or fluid on or around the shock body. Use this guide to replace the front shocks in your 2WD V8 '97-'04 Dodge Dakota if you believe your current shocks are failing.
- Note: Always replace the shocks in pairs to prevent potentially unsafe handling characteristics.
Выберете то, что вам нужно
Park the truck on a flat surface with the wheels turned so you can access the shocks easier.
Locate the shock's top nut.
Place a jack under the front cross brace and raise the truck until the tire on the side you are working on is off the ground.
Place a jack stand under the frame rail behind the tire of the side you are working on.
Gently lower the truck onto the jack stand.
Use a 14 mm box end wrench or deep socket wrench to turn the top strut nut counterclockwise until it is loose.
Finish removing the nut by hand.
Remove the rubber grommet and metal retainer.
Locate the two 10 mm hex bolts securing the bottom of the shock to the lower control arm. They are on the underside of the lower control arm.
Remove the two bolts by using a box end wrench or socket wrench to turn them counterclockwise.
Lower the shock out of the lower control arm.
Install a retainer and grommet onto the new strut if there isn't one already installed.
Insert the strut up through the lower control arm.
Ensure that the threaded end of the strut goes through the hole in the upper control arm.
Re-insert the two 10 mm bolts and tighten them until they are snug by turning them clockwise with a box end wrench or socket wrench.
Place the new grommet and retainer over the threaded end of the new shock. Be sure that the grommet and retainer are flush against the upper control arm.
Place the nut onto the threaded end of the new shock and turn it clockwise with a 14 mm box end wrench or deep socket wrench until it is snug.
Lift the truck up with the jack, and then remove the jack stand.
Slowly lower the truck and remove the jack.
Repeat this guide to replace the strut on the opposite side.
8 участников успешно повторили данное руководство.
6 Комментариев
Yeah right. If the %#*@ top shaft of the shock didn't keep on spinning.
If your in Canada or anywhere they use salt on the roads this will happen (spinning shaft syndrome) a cutting torch is your best friend, or a decent nut splitter). If you don't have either of these then using a wrench to hold the 14mm but and I believe a 8mm socket you can spin the shaft “clockwise”. If all else fails use a 14mm deep socket with a long extension and with a side to side motion break the threaded portion of the shaft off the shock. I have used all of these methods many times over as I live in Canada, one of the saltiest nations in the world. I hope this helps someone.
It's a ##&&% when the shock shaft keeps on spinning. 5 hrs today. Still not done.
I had to use an angle grinder to cut into the top of the shaft. Eventually it heated up and I was able to remove it. Also try to cut a slit to fit a flat head while you remove the nut. FYI, I did this on a messed up left hand, if can do it, it is possible.
Ramon -
Same as 4fisher; I can’t find a way to hold the shaft. WTH is the answer?
