1998-2002 Honda Accord Distributor Cap Replacement
Выберете то, что вам нужно
  1. 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: шаг 1, изображение 1 из 3 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: шаг 1, изображение 2 из 3 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: шаг 1, изображение 3 из 3
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
    There is a problem with the order, the first cylinder is on the right not on the left, always next to the timing pulley, the numbering is opposite.
    But following your reflection it is and all the same good
    Denis bache - Ответить
  2. 1998-2002 Honda Accord Distributor Cap Replacement: шаг 2, изображение 1 из 1
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. 1998-2002 Honda Accord Distributor Cap Replacement: шаг 3, изображение 1 из 2 1998-2002 Honda Accord Distributor Cap Replacement: шаг 3, изображение 2 из 2
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. 1998-2002 Honda Accord Distributor Cap Replacement: шаг 4, изображение 1 из 1
    • Pull the distributor cap away from the engine and set it aside.
  5. 1998-2002 Honda Accord Distributor Cap Replacement: шаг 5, изображение 1 из 2 1998-2002 Honda Accord Distributor Cap Replacement: шаг 5, изображение 2 из 2
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
Заключение
13 участников успешно повторили данное руководство.
4 Комментариев
I need to do this procedure. Have never done this in years. Next time I will change my wires, plugs and now my distributor cap.
Thurman - Ответить
Where can I find the part number?
lawendellr - Ответить
excellent, thanks for you aportation.
julio cesar - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 38
За последние 30 дней: 124
За всё время: 68,318
