Введение
Use this guide to replace fogged or damaged tail lights in your '98-'02 Honda Accord.
Выберете то, что вам нужно
Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
Carefully peel back the trunk liner from around the edge of trunk opening by the light.
Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
Repeat this process for the other light bulb socket.
Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
Turn the light bulb sockets counterclockwise and remove them from their holes.
Remove the connector at the bottom of the panel tail light assembly.
Locate the three 8 mm nuts holding the panel tail light assembly to the car and use an 8 mm socket wrench or box end wrench to remove the them.
Remove the three 8 mm hex nuts securing the trunk tail light using a socket wrench or box end wrench.
Lift the trunk tail light up from the outer edge, being careful not to break the plastic locator on the inside edge.
3 участников успешно повторили данное руководство.
4 Комментариев
My tail lights, brake lights stay on even after I have turn the key off and pulled it out of the keyhole. Is there a part that might be broken that could repair this. Any comments I would appreciate them. Thanks oh I did find little pieces on the floor and wondered what that part might be maybe under the drivers side where the spring is
I have to take the cable off the battery or it goes dead. And the little part on the floor was kind of like a plastic washer with a little pointed top on it.
Thanks Nathan. The part was broken into pieces. There is a little spring underneath the steering and, back in a little bit that I wondered if it broke off from that, which would make the break stay on.
