1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
Выберете то, что вам нужно
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: шаг 1, изображение 1 из 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: шаг 1, изображение 2 из 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: шаг 1, изображение 3 из 3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 2, изображение 1 из 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 2, изображение 2 из 2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 3, изображение 1 из 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 3, изображение 2 из 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 3, изображение 3 из 3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 4, изображение 1 из 1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 5, изображение 1 из 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 5, изображение 2 из 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: шаг 5, изображение 3 из 3
    • Put back the light housing and screw in the two Philips screws.
Заключение
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2 участников успешно повторили данное руководство.
Eric Wu
Участник с: 01/21/15
3 357 Репутация
Автор 23 руководств
2 Комментариев
The problem is there are no screws to remove.
richard - Ответить
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 34
За всё время: 5,987
