Введение
This tutorial will focus on the replacement of the six ignition coils of the 3 Series BMW (1999-2006) due to engine misfires. Some reasons for engine misfires can include rough idling and late shifting. The BMW series 3 (1999-2006) also needs regular replacements for the car’s ignition coils. BMW recommends replacing these ignition coils every 100,000 miles for non-turbocharged vehicles and every 45,000 miles for turbo-charged vehicles. With the help of this tutorial, you will have no problem keeping your BMW 3 series running smoothly and at its optimal performance.
Выберете то, что вам нужно
Release the hood latch by pulling the lever found in the driver foot well.
Open the hood.
Using a 10 mm socket wrench, remove the four bolts holding down the engine covers.
Note the placement of each ignition coil then remove the plastic latch and disconnect each cable.
With a firm grip, remove each ignition coil and replace with the new coils respectively.
4 участников успешно повторили данное руководство.
