1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement
Выберете то, что вам нужно
  1. 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Passenger side window regulator (power windows): шаг 1, изображение 1 из 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Passenger side window regulator (power windows): шаг 1, изображение 2 из 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Passenger side window regulator (power windows): шаг 1, изображение 3 из 3
    • First locate the 4 screws to remove the door panel. See pic1
    • 2 screws are visible.
    • The other 2 screws are behind items.
    • Location of the screws.
    • First screw is under the door lock/window controls. See pic 2.
    • Next screw located lower right of panel behind reflector. See pic 3
    • To remove the door/window controls pry on one end of the controls and lift up. See pic 2.
    • To remove the reflector pry one side and remove from the panel. See pic 3.
  2. 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Removing panel from door.: шаг 2, изображение 1 из 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Removing panel from door.: шаг 2, изображение 2 из 3 1999-2005 Pontiac Grand Am Passenger side window regulator (power windows) Replacement, Removing panel from door.: шаг 2, изображение 3 из 3
    • Before removing panel, remove small tweeter speaker from top of door panel.. Clipped in just pull the top. Pic 1
    • After removing screws, Pull on the panel around the outside to release the pop-in clips.
    • Then remove the panel from the door by lifting up and backward on the panel. Pic 2
    • Be mindful of the rail on top of the panel that may or may not fall off the panel.
    • Also make sure you remove any wires that is connected to the door panel. Lock controls, tweeter speaker wires.
    • On the bottom of the glass inside the door there are two bolts that hold the window to the plastic track on the regulator.
    • Before you remove the second screw hold the window to prevent breakage of the window.
    • While holding the window remove the second screw and lift out the window from the door.
    • Locate and loosen the 4 bolts holding the regulator. See pic 1.
    • Then remove the window regulator motor and all of the track from the door...
    • Then replace the regulator and reverse the procedure to install the regulator back in the door.
Заключение
4 участников успешно повторили данное руководство.
shawn streitmatter
Участник с: 11/25/13
251 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 15
За последние 30 дней: 36
За всё время: 8,899
