Выберете то, что вам нужно
Pull the hood release upwards to open the hood and use the prop rod to keep it open.
Check the fluid level is in between the max and the min mark on the coolant container. If it is at the max, proceed to step 7.
If the fluid level is below the max, you need to fill it up, continue to step 4.
If the coolant tank is empty, continue to step 4
Loosen the coolant cap a little, then step back while the pressure releases. Now, completely remove the coolant cap.
Place a funnel on top of the coolant container opening
Pour the Prestone coolant liquid into the container until the liquid reaches the “max” line.
If you have a funnel. Place the funnel into the top of the container.
Pour the coolant liquid into the funnel until the liquid reaches the “max” line.
Pour the Prestone washer liquid into the container until the liquid reaches the top of the container.
Еще один человек закончил это руководство.
