Введение
Here is a straight forward bulb replacement. Only requires the simplest of tools and is a quick fix.
Выберете то, что вам нужно
Here is a 2000 Jeep Grand Cherokee with a burned out driver side headlight bulb.
Open the hood. On top of the affected headlight assembly is a single 7mm hex bolt.
Remove the bolt
Remove the bolt. It is approximately 6 inches long.
Grab the headlight assembly on the fender side,
as well as the grill side.
Then pull the assembly straight out
The light bulbs will now be accessible.
Remove the bulb by twisting it in a counter clockwise direction, then pulling it out of the headlight assembly.
Use a flathead screwdriver (or similar tool) to lift the socket clip of the tab on the bulb and remove the bulb.
Change the bulb and the result will be fully functional headlights.
To reassemble your headlight, follow these instructions in reverse order.
18 участников успешно повторили данное руководство.
11 Комментариев
guide made this an ABC REPLACEMENT
Easy peasy. Thanks!
On my 2001 Jeep Grand Cherokee Limited, there was an extra screw that needed to be removed. I didn't notice it and, in trying to remove the headlight housing, broke the plastic housing that was held in place by that screw.
You didn't notice it? I wouldn't have you working on my car if you're that careless.
FixIt -
Justin answer the question we don't want to hear rude comments just the answer geeh dude so abrasive to ppl. C wats up wit that
