Выберете то, что вам нужно
Use a flathead screwdriver to remove the cap from the windshield wiper.
Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
8 участников успешно повторили данное руководство.
5 Комментариев
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
does it need to be programmed mine needs replacement my gears are not shifting
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
