Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
  1. Use a #2 Phillips screwdriver to remove the four screws.
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. Remove the rubber gasket from the rain tray.
    • Remove the rubber gasket from the rain tray.
  3. Lift the tray upwards and away from the vehicle.
    • Lift the tray upwards and away from the vehicle.
  4. Use a flathead screwdriver to remove the cap from the windshield wiper.
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Use a socket wrench to release the passenger-side windshield wiper locking nut.
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  7. Gently lift up the passenger-side windshield wiper. Gently lift up the passenger-side windshield wiper.
    • Gently lift up the passenger-side windshield wiper.
  8. Remove the driver-side windshield wiper in the same fashion.
    • Remove the driver-side windshield wiper in the same fashion.
  9. Lift up the plastic cover. Lift up the plastic cover.
    • Lift up the plastic cover.
  10. Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover. In a pinch, you can make this tool with a phillips driver bit and end wrench.
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  11. Use a #2 Phillips screwdriver to remove the front two screws.
    • Use a #2 Phillips screwdriver to remove the front two screws.
  12. Gently unplug and lift out the automatic transmission control unit. Gently unplug and lift out the automatic transmission control unit.
    • Gently unplug and lift out the automatic transmission control unit.
Заключение
7 участников успешно повторили данное руководство.
Matthew Newsom
Участник с: 05.01.2010
34 878 Репутация
Автор 67 руководств
Комментариев: 5
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Ответить
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Ответить
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Ответить
thank you very much .
emad_szs - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 37
За последние 30 дней: 160
За всё время: 35,452
