Введение
Remove the seat from your '99-'02 SV650 to gain access to your fuse box, tank hinge bolts and various other electrical connections.
Запчасти
Никакие детали не требуются.
  1. If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off. Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
      • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
Заключение
Phillip Takahashi
Участник с: 22.08.2011
75 509 Репутация
Автор 85 руководств
Один комментарий
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 13
За 30 дней: 37
За всё время: 4,642
