Введение
This guide shows the process for replacing a tail light bulb on a Honda CR-V 2001-2006, whether it is a turn signal, a brake light, or a reverse light. Bulbs have a life span and need to be replaced if fused or malfunctioning for personal and others' safety. Moreover, properly working tail lights is the legal responsibility of every driver. Replacing a tail light bulb on a Honda CR-V 2001-2006 is easy and knowing how to do it can save the driver time and a fair amount of money.
Выберете то, что вам нужно
Take off the tail lamp assembly by slightly pulling the low end using one hand.
Slide down the lamp a little bit and pull it off using both hands to separate it from its base.
