2001-2005 Honda Civic Oil level Check and oil change
Архивированное руководство
Это руководство сохранено для исторических целей. Используйте его обновлённую версию, чтобы выполнить ремонт.
Выберете то, что вам нужно
  1. 2001-2005 Honda Civic Oil level Check and  oil change, 2001-2005 Honda Civic Oil level Check and  oil change: шаг 1, изображение 1 из 1
    • Warning: Improper maintenance or use of unapproved materials may lead to major issues with your automobile
    • Step 1: Turn off your vehicle and wait a few minutes.
    • Starting this process with a running or hot car may cause damage to both the engine as well as the person performing the maintenance
  2. 2001-2005 Honda Civic Oil level Check and  oil change: шаг 2, изображение 1 из 1
    • Remove the dipstick from its' holder and wipe it down with a clean cloth
    • After cleaning, replace the dipstick and remove it again
  3. 2001-2005 Honda Civic Oil level Check and  oil change: шаг 3, изображение 1 из 1
    • If an oil change is not necessary, the oil will be a dark brown, and the level will be in between the two notches on the dipstick.
    • If the level is too high or low, it's time to add/change the oil
  4. 2001-2005 Honda Civic Oil level Check and  oil change: шаг 4, изображение 1 из 1
    • Step 1: After running the car to normal operating temperature, turn off the vehicle and remove the black and purple oil fill cap.
    • Underneath the car, use your ratchet socket wrench to remove the oil drain bolt and washer.
    • Remove the oil filter from the tank and allow all of the oil to drain out.
  5. 2001-2005 Honda Civic Oil level Check and  oil change: шаг 5, изображение 1 из 1
    • After all of the oil is drained out, replace all parts in reverse order that they were removed.
    • If the oil filter appears old or damaged, it is wise to replace it. Oil filters can be found at any auto parts store
    • Add 5W-20 Motor oil to the level indicated in your owners manual.
Заключение
7 участников успешно повторили данное руководство.
Tyler Smith
Участник с: 10/23/13
828 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 Участник UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G5
3 членов
Автор 5 руководств
2 Комментариев
Where is the oil filter located? An important step was left out!!
Gil - Ответить
This guide has been retired and is no longer being updated. Please use the latest version of the 2001-2005 Civic oil change guide. Thanks!
Jeff Suovanen -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 4,382
