2001 Audi TT Rear Differential Replacement
Выберете то, что вам нужно
  1. 2001 Audi TT Rear Differential Replacement, Getting Started: шаг 1, изображение 1 из 1
    • Lets get started! A car lift is recommended for this task but it can be done with just a jack if required.
  2. 2001 Audi TT Rear Differential Replacement, Remove the exaust and exaust shield: шаг 2, изображение 1 из 1
    • The exhaust is held in with two bolts at the middle of car underneath . It the hangs from 4 rubber mount wich can be unhooked with a small screw driver and some leverage.
    • Be careful not to tear the rubber mounts.
    • Sorry for missing images they were never taken during the exhaust removal.
  3. 2001 Audi TT Rear Differential Replacement, Axles: шаг 3, изображение 1 из 1
    • Dismount both axles from the rear differential.
  4. 2001 Audi TT Rear Differential Replacement, Ground Strap: шаг 4, изображение 1 из 1
    • Dismount the ground strap located to the left of the driver side rear axle hub.
  5. 2001 Audi TT Rear Differential Replacement, Drive Line Hub: шаг 5, изображение 1 из 1
    • Dismount the drive line from the rear differential.
  6. 2001 Audi TT Rear Differential Replacement, Remove Tank Shield: шаг 6, изображение 1 из 1
    • Removing the passenger side gas tank shield will make step 7 easier.
  7. 2001 Audi TT Rear Differential Replacement, Remove Bracket: шаг 7, изображение 1 из 2 2001 Audi TT Rear Differential Replacement, Remove Bracket: шаг 7, изображение 2 из 2
    • Remover the two main bolts.
  8. 2001 Audi TT Rear Differential Replacement, Remove Bracket 2: шаг 8, изображение 1 из 2 2001 Audi TT Rear Differential Replacement, Remove Bracket 2: шаг 8, изображение 2 из 2
    • Remove other smaller bolts.
  9. 2001 Audi TT Rear Differential Replacement, Unbolt From Car: шаг 9, изображение 1 из 1
    • Remove the 4 bolts on both sides that hold the rear differential in the car.
    • Be sure to have some sort of jack or object to hold the rear differential into the car as you continue to work.
Заключение
Еще один человек закончил это руководство.
Brenden Mitchell
Участник с: 02/25/18
196 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 25
За всё время: 3,022
