Введение
In this guide you will be instructed on how to easily change the windshield wipers on your 2001 Nissan Sentra . Wiper blades should be replaced every six months or as soon as you notice a difference in driving visibility. When wiper blades no longer make contact with the windshield surface, because they wear off, begin to squeak, smear or streak, they should be replaced. If they are used when they are no longer working properly, it can result in poor visibility on the road, and can end up causing an accident. With this guide, you will be able to follow simple steps and easily replace your old windshield wiper blades.
Выберете то, что вам нужно
Measure the wiper blades to make sure they are the correct size.
Push the button until it clicks.
Lift the lock cover and then push the blade down, rotating it slightly and lift it upwards.
Once the wiper blade is accommodated, close the tab. Pull it upwards to lock it.
You have replaced the windshield wiper blades on your Nissan Sentra
