Введение
Replacing the headlights on your vehicle might seem like a complicated process. However, it is very simple and could take you less than 30 minutes. You’ll know to change them when you notice a sudden decrease in the quality of your headlights. One special requirement I suggest is to wear gloves when handling the new headlight bulb. This is because you don’t want the oil from your skin to get on the bulb and already decrease it’s quality. This is a step-by-step guide on how to change the headlights in a 2005 Chevrolet Trail Blazer.
Выберете то, что вам нужно
Pop off the clips that are holding the headlight in place. Then you will be able to slide the headlight out and have easy access to the bulb.
Turn the bulb halfway to pull it out. Then deattach the wires connected to the old bulb and remove old bulb.
Insert your new bulb. Turn half way once it is in to lock it in place. Then attach wires to new bulb. Finally, put the cap over the hold where the bulb goes
2 участников успешно повторили данное руководство.
Один комментарий
what about the headlight washers, on the NorthFace Edition
