2002-2008 Dodge Ram 1500 Coolant replacement
Выберете то, что вам нужно
  1. 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: шаг 1, изображение 1 из 3 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: шаг 1, изображение 2 из 3 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: шаг 1, изображение 3 из 3
    • Locate the coolant reservoir, near the front of the engine bay.
    • Do not remove the reservoir cap if the engine has overheated. Doing so may result in a steam explosion as pressure is released.
    • Locate the coolant reservoir cap and remove it by pressing down and turning it counterclockwise.
    • Never fill up the coolant while the engine is hot. This may cause the engine block to crack.
    • If the coolant level is low, fill up the reservoir using a 50/50 mixture of antifreeze and distilled water.
    • Many types of antifreeze coolant are pre-mixed, so read the instructions on the bottle before diluting with water.
  2. 2002-2008 Dodge Ram 1500 Coolant replacement: шаг 2, изображение 1 из 3 2002-2008 Dodge Ram 1500 Coolant replacement: шаг 2, изображение 2 из 3 2002-2008 Dodge Ram 1500 Coolant replacement: шаг 2, изображение 3 из 3
    • If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine.
    • Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay.
    • Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
    • Dispose of your used coolant at an auto parts shop or a landfill that accepts hazardous materials. Do not pour it down a storm drain or sink.
    • Remember to refill the reservoir tank with coolant before driving your Dodge truck. Driving without coolant will cause overheating and engine damage.
    • Due to limited resources the coolant was not actually drained in this guide.
Заключение
To dispose of your used coolant, take it to an automotive parts store or to any landfill that accepts hazardous materials. Do not pour coolant down any drains or sinks. Serious ecological damage could occur.
4 участников успешно повторили данное руководство.
Michael Saggese
Участник с: 10/05/12
1 021 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-24, Amido Fall 2012 Участник Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 членов
Автор 11 руководств
Один комментарий
Thanks a million very helpful advice !
kenneth.williamsbam - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 39
За последние 30 дней: 150
За всё время: 55,203
