2002-2008 Dodge Ram 1500 Differential Oil Replacement
Выберете то, что вам нужно
  1. 2002-2008 Dodge Ram 1500 Differential Oil Replacement, Differential Oil: шаг 1, изображение 1 из 2 2002-2008 Dodge Ram 1500 Differential Oil Replacement, Differential Oil: шаг 1, изображение 2 из 2
    • Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential.
    • Position an oil pan under the differential.
    • Loosen the bottom 4 bolts first with the 14mm socket wrench. Slowly loosen the rest of the bolts in a random order until oil flows out and enters the drain pan.
    • Due to limited resources the oil was not actually replaced in this guide.
  2. 2002-2008 Dodge Ram 1500 Differential Oil Replacement: шаг 2, изображение 1 из 1
    • When tightening the bolts on the diff plate it is vital that you tighten them in a star pattern to avoid warping the plate. Do not exceed a torque of 40 ft-lbs per bolt.
    • Repeat the last step in reverse to re-tighten the bolts on the differential cover while following the star method of tightening bolts. Use a torque wrench to ensure proper torque specifications.
    • Now the differential is fully sealed and ready for new oil.
  3. 2002-2008 Dodge Ram 1500 Differential Oil Replacement: шаг 3, изображение 1 из 2 2002-2008 Dodge Ram 1500 Differential Oil Replacement: шаг 3, изображение 2 из 2
    • Locate the differential filler plug.
    • Use a #2 flathead screwdriver to lift the outer lip of the plug. Pinch the outer lip of the rubber filler plug between your fingers and pull off.
    • Use a vacuum pump to pump in new differential fluid until the oil level reaches the bottom of the plug hole.
    • Re-insert the rubber filler plug.
    • Due to limited resources the differential oil was not changed in this guide.
Заключение
5 участников успешно повторили данное руководство.
Ken
Участник с: 10/05/12
548 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-24, Amido Fall 2012 Участник Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 членов
Автор 11 руководств
2 Комментариев
Don’t forget the clean the old gasket material off, wipe up any differential fluid residue, clean the mating surface with brake cleaner, and add a new gasket maker material.
This guide really left out some very important steps. And don’t reuse your diff fluid people.
N S A (Nick) - Ответить
No mention of anti-slip additive which is not optional.
Ralph Parker - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 26
За последние 30 дней: 96
За всё время: 36,806
