Введение
This guide demonstrates how to remove and replace fuses for your Dodge truck.
Выберете то, что вам нужно
Open the hood by pulling the hood lever in the driver-side footwell.
Reach under the center of the grille and press the hood latch.
Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
Unscrew the plastic nut that holds the cover of the fusebox in place.
Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
Remove the fuse grabber from its holder.
Use the fuse grabber to carefully pinch the fuse.
Pull the desired fuse out.
Which fuse controls the fan for the air conditioning heating unit panel in the cab of the truck
See those yellow ones with wings, and the black one? What's the secret of those? I don't want to break it
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
11 участников успешно повторили данное руководство.
21 Комментариев
I need to find the flasher
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
Half of my fuse box only works.Wat could b wrong .I need help
Half of my fuse box only works.Wat could b the problem
il a tu une fusible pour la chauffrette si oui où elle est,merci
je voudrais savoir s’il a des fusibles pour la chauffrette car ce matin ma chauffrette ne marche plus merci
Where is the starter relay on a 2008? It’s not under the fuse box
are the fuse boxes the same for 2002-2008 ram 1500s? My husband needs to replace his 2008 1500 fuse box, and we found a 2005 fuse box, will that work?
How do you pull those big suckers on the right? I don’t want to put too much work to it for fear of damaging something.
Same here. That's what I was actually looking for
Same here, #'s 1-15?
Thank you for staying the obvious but what about fuse specifics to ensure proper replacement?
Find exactly what you are looking for?
"Stating the obvious," looks like it helped some other's on here?
Why so pissy with condescending comment because he couldn't read your mind about what you were looking for, specifically?
SMH! Always one!
I can't find the flasher relay
Dodge 2008 pickup Fusebox has no location stating airbag for fuse on lid of box and no location stated inside of fuse area! Is there any other place to look? Or would it be hooked up to another location, such as radio, AC, ETC.?
Which one is the cigarette lighter fuse
brigsby384 - Ответить
