Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide demonstrates how to remove and replace fuses for your Dodge truck.
Выберете то, что вам нужно
Open the hood by pulling the hood lever in the driver-side footwell.
Reach under the center of the grille and press the hood latch.
Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
Unscrew the plastic nut that holds the cover of the fusebox in place.
Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
Remove the fuse grabber from its holder.
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
11 участников успешно повторили данное руководство.
21 Комментариев
I need to find the flasher
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
