Введение
In this guide, I will provide step-by-step instructions on how to replace the windshield wipers on a 2002-2006 Acura Integra (RSX). I will also provide some tips on how to choose the right wipers for your vehicle, as well as some common errors to avoid when replacing your wipers. Whether you are an experienced DIYer or a first-time wiper replacement enthusiast, I hope that this guide will provide you with the information you need to successfully replace your wipers and keep your windshield clear of any obstructing debris. Let's get started!
To begin this guide, all that is needed is a towel or piece of cloth, a measuring tape, and new windshield wipers. Don't know what windshield wipers to get ? Don't worry, in this guide I've included some steps to help you choose your new windshield wipers.
Before beginning, power off the ignition and engage the parking brake.
Выберете то, что вам нужно
Use the tape measure to measure the length of the wiper blades from top to bottom.
Lift the windshield wiper off the windshield.
Place a towel underneath the wiper to prevent damage to the windshield if the wiper is dropped.
Lift open the clip above the wiper with one hand while holding the wiper arm up with the other.
Grab the wiper with one hand while holding the wiper arm up with the other.
Slide the wiper down.
Once unhooked, pull the wiper back and away from the wiper arm to remove the wiper.
Place the replacement wiper against the wiper arm with the hooking mechanism facing the hook of the wiper arm.
Slide the wiper up, thus putting it into place.
Once the wiper is slid up all the way, grab the top clip of the wiper.
Close the clip until a click is heard.
Remove the towel and lower the wiper arm down gently.
Follow these instructions for the second windshield wiper.
