Введение
This guide will show you how to replace a battery in the 2002-2006 Toyota Camry key fob. The key fob is needed to unlock, and lock your vehicle and easily access it.
Запчасти
  1. Purchase a new lithium coin battery. You can find it at your local hardware store. The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. Use your hands or a spudger to separate the key fob into two pieces.
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. Identify which part of the FOB holds the battery.
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. Remove the battery from the fob by releasing it from the holder using a spudger or by hand. Be careful that you don't break the contacts when removing the battery.
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. Insert the new battery by pushing it down.
    • Insert the new battery by pushing it down.
  6. Reassemble the fob,  using  your hands to press the two parts together.
    • Reassemble the fob, using your hands to press the two parts together.
Заключение
Salman Abu Mazen
Участник с: 27.09.2021
133 Репутация
1 руководство автора
Команда
UM-Willis-F21S51G7 Участник UM-Willis-F21S51G7
Community
1 член
Автор 1 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 20
За всё время: 30
