Введение
If your 2002 Ford F150’s rear door latch is stuck, this guide will demonstrate how to replace that latch.
There are a lot of small and fragile pieces within the door mechanism, be cautious not to damage or drop anything within the door. Any damage caused to the inner mechanisms of the door could potentially create a more expensive problem to your rear door.
Be careful when removing the door cover to not pull too hard. There are plastic door clips on the other side that could break with enough stress enacted upon it.
Выберете то, что вам нужно
Remove the Phillips #2 screws holding the window actuator mount to the door.
Place a wedge (or your finger) under the top part of the door cover. The cover will pull right off when all the clips are unlatched.
Once the top cover is off, remove the screws holding the lower door card on with a Phillips #2 screwdriver.
Carefully pull the stripping back from the hinge corner depending on which door you are repairing.
Take a pair of pliers and press on the halves of the fitting on the bracket.
Push the fitting through to release the cable clamp from the bracket.
Press the fitting back into the bracket and grab it again with the pliers to make sure that it is seated properly.
Slide the bottom ridge of the fitting onto the bracket. You will see it positioned like this.
Test the door handle to make sure that the door opens and closes.
After the latch is fixed, test the door again and then follow steps 1 and 2 in reverse order to return the door back to working order.
2 участников успешно повторили данное руководство.
