Введение
It is very easy to remove and replace your headlights in your 2002 Toyota Tacoma. You can save a lot of time by replacing the bulb yourself. The replacement is a H4 9003 bulb. The process is easy and requires no tools to get the job done.
Выберете то, что вам нужно
Pull up on the lever under the hood.
At the same time, lift the hood of the car.
Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
Еще один человек закончил это руководство.
