Введение
Are your headlights giving you trouble and need to replace them? This guide will show you how to easily replace those malfunctioning lights.
Выберете то, что вам нужно
Locate the handle to open the hood. It will be on the driver side of the car to the left.
Pull up on the handle and the hood should pop open a small amount.
Reach under the hood in the front where there is a small notch and pull the latch up. This will allow the hood to open all the way.
Locate the prop and insert it into the hole in the hood.
Locate the bulb. It will be in the front and to the side. Start with the side opposite from the battery.
10 участников успешно повторили данное руководство.
Один комментарий
Change headlight on your corolla in under one minute. So easy.
