Введение
This tutorial will go over how to replace a 2012 Nissan Versa car's interior dome lights. Your prior automotive experience is unimportant because changing the lightbulb within the dome light is a fairly easy procedure. It's crucial to understand how to change these lights, though. For your interior car light, you'll need a DE3175 lightbulb in addition to an opening tool in case something becomes jammed. Since you'll be removing the lightbulb with your hands, one thing to watch out for is its heat. You may quickly have brilliant interior lights if you just follow the instructions.
Выберете то, что вам нужно
Take off the inner dome light's plastic covering. Either with an opening tool or your hands.
Replace the dead or broken bulb with a new bulb by inserting a side in the hole first then pushing it upwards past the tab to seal it inside.
Make sure the lightbulb and socket are operational by turning on the light by pushing the switch.
To put the clear cover back you insert the side with one large hinge to the open space hinge.
The light assembly has a hinge, which clips back in
Once the lid is pressed into place with your fingertips till you hear a click to indicate you sealed it, your car will be illuminated by a new light.
