2004-2010 Volkswagen Touareg European Headlight Switch Replacement
Выберете то, что вам нужно
  1. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement, European Headlight Switch: шаг 1, изображение 1 из 1
    • First, remove the existing headlight switch.
    • Turn the switch to the off position (note that this pic was taken with the new light switch already in place).
  2. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 2, изображение 1 из 1
    • Push the center of the switch in.
  3. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 3, изображение 1 из 1
    • While keeping it depressed, rotate the switch to the right. It will turn slightly.
  4. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 4, изображение 1 из 2 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 4, изображение 2 из 2
    • Now pull the switch out of the dash.
  5. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 5, изображение 1 из 2 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 5, изображение 2 из 2
    • Remove the connector from the switch by depressing the release tab and pulling the connector out.
  6. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 6, изображение 1 из 1
    • Cut the existing zip tie - the original one should be black.
    • Again, this pic was taken after the install was complete, so you're seeing the replacement white zip tie here.
  7. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 7, изображение 1 из 2 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 7, изображение 2 из 2
    • Remove the connector from the housing itself. Do this with a small flat blade screw driver.
    • Pry up the locking mechanism and push the connector out of its shell.
    • With the right size screw driver, you can do this in one motion.
    • See the pics showing the housing (already separated from the connector) with the screw driver in place showing the right way to pry the lock open and push out the connector.
  8. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 8, изображение 1 из 1
    • Now with the connector removed, locate socket 7.
    • Remove the socket by pressing the release tab on the socket (see picture) and pulling the wire out of the connector.
  9. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 9, изображение 1 из 1
    • Now fold the wire back up against the harness and use the electrical tape to hold it in place.
    i needed to know what each wire do my replacement wires are a different color i got 9 wires
    reditt home - Ответить
  10. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 10, изображение 1 из 2 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 10, изображение 2 из 2
    • Slide the connector back into the housing and replace the zip tie you cut earlier.
  11. 2004-2010 Volkswagen Touareg European Headlight Switch Replacement: шаг 11, изображение 1 из 1
    • Plug the harness into your new euro headlight switch and push it back into the dash.
    • Rotate the switch to the off position to allow the center to pop back out and engage the lock.
Заключение
3 участников успешно повторили данное руководство.
Justin
Участник с: 10/27/12
1 496 Репутация
Автор 3 руководств
3 Комментариев
Was the purpose of installing the Euro Headlight Switch, to allow you to have automatic lights? I would like to have automatic lights, thats why I ask.
thebigdoan - Ответить
Does this allow you to have the lights off, and not always on.
Izzy Martinez - Ответить
Hi. Which pin is for front fog light? My Touareg wasn’t fitted with front fog light and i need to retrofit them but can’t find the wiring diagram for this light switch. I have European edition of Touareg. Thank you !
Cristi Geo - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 13
За последние 30 дней: 78
За всё время: 14,395
