2004-2008 Mazda RX-8 Air Filter Replacement
  1. 2004-2008 Mazda RX-8 Air Filter Replacement, Air Filter: шаг 1, изображение 1 из 1
    • Begin by opening the hood of the vehicle and locating the air filter cover.
    • The air filter is located in the middle of the front of the vehicle covered by a large black rectangular cover.
  2. 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 2, изображение 1 из 3 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 2, изображение 2 из 3 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 2, изображение 3 из 3
    • Locate the two tabs on either side of the front of the air filter cover. Grab and pop open these two tabs.
    • Push the air filter cover open with your fingers. The air filter will now be visible and begin to pop up.
    • Once the air filter pops up, you can grab it with your hands and begin to remove it from the cover that is still being held open.
  3. 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 3, изображение 1 из 2 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 3, изображение 2 из 2
    • Gently pull the entire air filter out of the opened cover. This might take more than one set of hands in order to keep the cover open during removal.
    • The air filter is now fully removed and outside of the air filter cover. Obtain a new air filter to replace the old one.
  4. 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 4, изображение 1 из 3 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 4, изображение 2 из 3 2004-2008 Mazda RX-8 Air Filter Replacement: шаг 4, изображение 3 из 3
    • Pry apart the cover of the air filter again to begin inserting your new air filter.
    • Gently push the new air filter back into the opened air filter cover the same way you removed it. The air filter will fall back into its resting position.
    • Once the new air filter has been fully inserted into the cover, close the cover and push the two tabs on the outside of the cover closed.
Финишная черта
2 участников успешно повторили данное руководство.
Laura Pritchard
Участник с: 04/20/15
199 Репутация
1 руководство автора
Команда
Cal Poly, Team 8-4, Regan Spring 2015 Участник Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 4,106
