Введение
This guide will show you how to diagnose and fix the common issue with the 2004-2010 Toyota Sienna sliding door.
The repair is easy but patience is a must as you do not want to strip the screws.
Выберете то, что вам нужно
Видео обзор
First, test both sliding doors to identify the problem with the driver's side door
Carefully remove the door panel by lifting it out and disconnect the power window
Close the door and observe the actuator motor on the working passenger side door for comparison
On the driver's side door, test the voltage to confirm it's an issue with the actuator motor and not an electrical problem
Order a replacement actuator motor (Part #s in the video) and wait for its arrival
Remove the window regulator by lowering the window and accessing the bolts through the portholes
Remove the actuator motor by grinding off the stripped Phillips screws with a Dremel tool or using vice grips
Replace the actuator motor with the new part, using socket screws from wall sockets or light switches if necessary
Еще один человек закончил это руководство.
