Введение
This will be a Fast Fix guide on how to fix the headlights for either side of a 2010 Honda Odyssey. This guide is to help you when your headlights may stop working for any reason. There are no Tools needed for this guide. The only thing you will need is a replacement light bulb.
Выберете то, что вам нужно
Pull the lever under the hood of the car, right above the Honda logo, to release the hood.
Lift the hood strut and insert the end of the strut into the corresponding groove.
Turn the socket counterclockwise to release it from its housing.
Pull the bulb directly out of its socket.
Now remove the hood mount and close the hood you should hear a loud sound when it is completely closed and it should be flush with the rest of the vehicle
Еще один человек закончил это руководство.
