Введение
This is a step-by-step guide on how to replace a sun visor in a 2005 Honda CR-V. With time, you will see that the sun visor will experience some wear and tear, which is an indication that your sun visor should be replaced with a new one. One suggestion that I would like to recommend for your safety is to wear gloves when utilizing any tools.
Prior to beginning these steps, be sure that the car is shut off. Place the car in park and engage the parking brake.
Выберете то, что вам нужно
Press the switch on the left of the parking lever, pull it outwards, and release it when it is fixed and outward.
Remove the outer shell with a spudger.
When the outer shell is loose enough, remove it with your hand.
Put the 4.5 mm screw removed in the previous step in the new sun visor.
Tighten the screw using a Torx screwdriver.
Screw in the rest of the 4.5 mm screws back in the sun visor using a Torx screwdriver.
To replace the new sun visor with the old sun visor, follow these steps in the same order.
