Введение
Having your vehicle struts crack, break, or simply stop working is a very common problem with cars today. Without working struts on the trunk of your car, it is difficult to open and close your trunk.
Инструменты
Запчасти
  1. Begin by placing a support beneath the trunk that takes all the weight of the trunk.
    • Begin by placing a support beneath the trunk that takes all the weight of the trunk.
  2. Insert the flat head screwdriver under the clip,  at the top of the strut, and lift the clip until it pops off completely.
    • Insert the flat head screwdriver under the clip, at the top of the strut, and lift the clip until it pops off completely.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Now, insert the flat head screwdriver under the clip,  at the bottom of the strut, and lift the clip until it pops off completely.
    • Now, insert the flat head screwdriver under the clip, at the bottom of the strut, and lift the clip until it pops off completely.
  5. Line up the ball and the socket pieces of your new strut.
    • Line up the ball and the socket pieces of your new strut.
  6. Use force to push the strut and connect the ball and socket joint.
    • Use force to push the strut and connect the ball and socket joint.
Заключение
Kayla Peterson
Участник с: 04.02.2019
148 Репутация
1 Guide authored
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 41
